[GSAS-II] Synchrotron parameter file
Bartłomiej Gędziorowski gedzior at agh.edu.pl
Fri Nov 22 06:08:26 CST 2019
Yes,
I know it sounds crazy, but if someone chose by mistake a wrong set than
it would be nice to have the possibility to easily correct mistake. I
think it would be easy to implement it by adding to the menu a position
and use the same dialog window used during adding a histogram.
Bartek
W dniu 22.11.2019 o 10:47, Von Dreele, Robert B. pisze:
> Hi,
> You want to switch from one default to another? Say from lab CuKa to
> synchrotron (or vice versa)?
> Bob
> P.S. I'm not up early in Chicago. I'm in the UK for 6 months.
> On 11/22/2019 9:43 AM, Bartłomiej Gędziorowski via GSAS-II wrote:
>> Dear Bob,
>> yes, I know that, but there I can only select parameters from file,
>> or reset to default values. There is no way to chose different type
>> of default profiles, the same way it can be done when you load
>> histogram and press 'cancel' on profile prompt.
>> Bartłomiej,
>> W dniu 22.11.2019 o 10:36, Von Dreele, Robert B. pisze:
>>> Dear Bartlomiej,
>>> There are Save & Load menu items in Instrument Parameters for saving
>>> a set of profile coefficients & then reading them in. If you do this
>>> for the same histogram, it will reset the default values.
>>> Bob
>>> On 11/22/2019 9:30 AM, Bartłomiej Gędziorowski via GSAS-II wrote:
>>>> Thank You Brian,
>>>> i did it exactly same thing, but I was thinking that maybe someone
>>>> here did measurements on this very equipment and got the parameter
>>>> file.
>>>> However, I've got another question, this time about GSASII menus.
>>>> The instrument parameters that can be refined for typical XRD are
>>>> slightly different than these for synchrotron. E.g., for XRD we can
>>>> select the type of radiation, and for synchrotron the wave length.
>>>> Is there any way to change the parameters set, other than removing
>>>> the histogram and adding it again?
>>>> Bartłomiej
>>>> W dniu 21.11.2019 o 17:52, Toby, Brian H. pisze:
>>>>> You might try one of the generic parameter sets (press cancel at
>>>>> the parameter dialog) or just start with peak fitting to get
>>>>> parameters from the pattern you have, (see Determining Starting
>>>>> Profile Parameters from a Standard
>>>>> <https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/CWInstDemo/FindProfParamCW.htm>).
>>>>> Either way you will not be able to get useful information on size
>>>>> and microstrain, but you can start without an instrument parameter
>>>>> file.
>>>>> Brian
>>>>>> On Nov 21, 2019, at 10:00 AM, Bartłomiej Gędziorowski via GSAS-II
>>>>>> <gsas-ii at aps.anl.gov <mailto:gsas-ii at aps.anl.gov>> wrote:
>>>>>> Dear all,
>>>>>> My colleague got a pattern from a synchrotron 'BL02B2 —
>>>>>> SPring-8'. I tried to help him with the refinement; however, it's
>>>>>> my first attempt to fit synchrotron data and we don't have the
>>>>>> parameter file. The colleague wrote an email to the operators,
>>>>>> but we didn't get any response. I'm wondering if anybody did some
>>>>>> measurements there and got the parameters? I will appreciate any
>>>>>> help.
>>>>>> I post the link to the website of the synchrotron.
>>>>>> http://www.spring8.or.jp/wkg/BL02B2/instrument/lang-en/INS-0000000318/instrument_summary_view
>>>>>> Best regards,
>>>>>> Bartłomiej
>>>>>> Bartłomiej Gędzioroski, Ph.D.
>>>>>> AGH University of Science and Technology,
>>>>>> Faculty of Energy and Fuels,
>>>>>> Department of Hydrogen Energy,
>>>>>> al. Mickiewicza 30
>>>>>> 30-059 Krakow, Poland
>>>>>> _______________________________________________
>>>>>> GSAS-II mailing list
>>>>>> GSAS-II at aps.anl.gov
>>>>>> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20191122/3ced0bb3/attachment-0001.html>
More information about the GSAS-II mailing list
