[GSAS-II] Pawley refinemet question
Sergey Ushakov svushakov at ucdavis.edu
Wed Apr 8 12:58:15 CDT 2020
Greetings! I have a question maybe not specific to GSAS-II but more about
Pawley vs Le Bail fitting of powder XRD data.
I work on high temperature data from laser-heated solid spheroids which
rotate in a gas flow in aerodynamic levitator.
The data are collected in transmission geometry at 6-ID-D at APS.
The rotation is not well controlled since it depends on the shape of each
bead formed by melt solidification, i.e., on surface tension, volume change
on melting, etc.
So, sometimes data are very much powder-like and amenable to Rietveld
refinement of the structure, but sometimes they are not, and in this case,
I do Pawley fit for cell parameters.
I used to do Le Bail fitting for that in GSAS-I, but I understand that it
was replaced by Pawley refinement (although there is an option for Le Bail
extraction of intensities?).
To my surprise, Pawley fit in GSAS-II yield phase/weight fraction if one
turns it on for refinement.
I thought phase fraction could be correctly refined only from Rietveld?
I would appreciate any comments on this!
Sergey
Sergey Ushakov PhD
Staff Research Associate
Peter A Rock Thermochemistry Laboratory and NEAT ORU
Rm 4415, Chemistry Annex
University of California, Davis
Davis, CA 95616
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200408/36fe4e9c/attachment.html>
More information about the GSAS-II mailing list
