[GSAS-II] BUG report (GUI) GSASII
Ivo Alxneit
ivo.alxneit at psi.ch
Tue Apr 21 03:28:01 CDT 2020
Dear all
I was running a refinement on a single histogram with (initially three
phases). After a few refinements I deleted a phase and continued. In the
'.lst' file only the results for the two remaining phases are now
reported. When I select the histogram in the tree-window, the GUI,
however, reports results for three phases. The entry for the last phase
(in the tree) is repeated twice. The first entry is correct (same
numbers as in '.lst') while the second spurious entry reports diffferent
numbers that do not change on subsequent refinements.
GSAS-II binary directory:
/home/alxneit/share/miniconda3/envs/gsas/GSASII/bindist
7 values read from config file
/home/alxneit/share/miniconda3/envs/gsas/GSASII/config.py
09:45:15: Debug: Adding duplicate image handler for 'Windows bitmap file'
Python module versions loaded:
Python: 3.7.7
wx: 4.0.4
matplotlib: 3.1.3
numpy: 1.18.1
scipy: 1.4.1
OpenGL: 3.1.1a1
Image: 7.0.0 (PIL or Pillow)
Platform: linux 64bit x86_64
Max threads:2
This is GSAS-II revision 4379 (SVN version 4379)
gruss
Dr. Ivo Alxneit
Applied Catalysis and Spectroscopy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/ceg/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200421/74718a35/attachment.sig>
More information about the GSAS-II
