[GSAS-II] sequential refinement throws an exception if it hits a singular matrix
Wolfman, Mark
wolfman at anl.gov
Thu May 7 16:13:36 CDT 2020
Hi, GSAS-II.
I'm not asking for help with the singular refinement error
itself. Instead, I wanted to share a small fix that allows sequential
refinement to exit gracefully instead of throwing an unhandled
exception. This is for version 4415 (reported as latest version by
help/check for updates).
If an error occurs during sequential refinement (in this case, a
singular matrix), the *SeqRefine* function still tries to read the
results but fails because some of the parameters are not set. This
happens on line 514::
Refining with PWDR nmc811_350_nioh_bn_1_LH_00150.csv
Warning: **** Refinement failed - singular matrix ****
Bad parameter: 0:150:Size;i
Traceback (most recent call last):
File "/home/mwolf/miniconda3/envs/gsas/GSASII/GSASIIdataGUI.py", line 4957, in OnRefine
self.OnSeqRefine(event)
File "/home/mwolf/miniconda3/envs/gsas/GSASII/GSASIIdataGUI.py", line 5140, in OnSeqRefine
OK,Msg = G2stMn.SeqRefine(self.GSASprojectfile,dlg,refPlotUpdate) #Msg is Rvals dict if Ok=True
File "/home/mwolf/miniconda3/envs/gsas/GSASII/GSASIIstrMain.py", line 514, in SeqRefine
Rvals['Rwp'],Rvals['chisq'],Rvals['GOF']**2,Rvals['DelChi2'],Rvals['Max shft/sig']))
KeyError: 'Max shft/sig'
An easy fix is to replace the last ``Rvals['Max shft/sig']`` with a
``Rvals.get('Max shft/sig', np.nan)``. Not sure if *np.nan* is the
right choice, but at least the SeqRefine function can now stop
gracefully and load the partial results.
Cheers,
This message is signed with Pretty Good Privacy (PGP) key BE1E3158.
http://pool.sks-keyservers.net/pks/lookup?op=get&search=0x457826FCBE1E3158
Desc: not available
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200507/31003cb7/attachment.sig>
More information about the GSAS-II
