[GSAS-II] clear simulation when using phython API
Joress, Howie (Fed)
howie.joress at nist.gov
Fri May 8 08:02:10 CDT 2020
I am trying to run a simulation in a loop. Currently, I am creating a new .gpx on each iteration then reloading everything which seems like it is increasing the time per loop. This seems necessary to reset the simulated histogram. is there a better way to clear the histogram? The GUI version would be to simply hit the edit range button and then ok. How can this be replicated in the API?
Howie
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200508/ef9d0df7/attachment.html>
More information about the GSAS-II
