[GSAS-II] Question about locating files
Toby, Brian H. toby at anl.gov
Wed May 13 13:25:38 CDT 2020
Lisa,
I think if you move the .gpx file and images so they are in the same directories relative to where they were or in the exact same directory, they will be found without asking.
E.g. if you had the
images in /home/me/Jan2020/images/myimage.tif
and projects in /home/me/Jan2020/gpx/my.gpx
then moving both to
/work/Jan2020/gpx/my.gpx and /work/Jan2020/images/myimage.tif
should work. I think that
/work/gpx/my.gpx and /work/images/myimage.tif
will also, but I am not sure. I intended that
/work/my.gpx and /work/myimage.tif
should also work. Let me know about problems.
Brian
On May 13, 2020, at 12:32 PM, Lisa Van Loon via GSAS-II <gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>> wrote:
Hi everyone,
I did a search of the archive but couldn't find an answer to my question.
I have created a GSAS-II gpx project with a number of images loaded in. I want to go back and re-interrogate the data, but I have moved the original data folder to a new location. GSAS is looking for the files and I have to open the folder in its new location for each image. Is there a way to change this?
Lisa
GSAS-II mailing list
GSAS-II at aps.anl.gov<mailto:GSAS-II at aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200513/0bd63e49/attachment.html>
More information about the GSAS-II mailing list
