[GSAS-II] Question about locating files
Lisa Van Loon lisavanloon at gmail.com
Wed May 13 15:11:27 CDT 2020
Thanks! I'll give it a try.
On Wed, May 13, 2020 at 1:25 PM Toby, Brian H. <toby at anl.gov> wrote:
> Lisa,
> I think if you move the .gpx file and images so they are in the same
> directories relative to where they were or in the exact same directory,
> they will be found without asking.
> E.g. if you had the
> images in /home/me/Jan2020/images/myimage.tif
> and projects in /home/me/Jan2020/gpx/my.gpx
> then moving both to
> /work/Jan2020/gpx/my.gpx and /work/Jan2020/images/myimage.tif
> should work. I think that
> /work/gpx/my.gpx and /work/images/myimage.tif
> will also, but I am not sure. I intended that
> /work/my.gpx and /work/myimage.tif
> should also work. Let me know about problems.
> Brian
> On May 13, 2020, at 12:32 PM, Lisa Van Loon via GSAS-II <
> gsas-ii at aps.anl.gov> wrote:
> Hi everyone,
> I did a search of the archive but couldn't find an answer to my question.
> I have created a GSAS-II gpx project with a number of images loaded in. I
> want to go back and re-interrogate the data, but I have moved the original
> data folder to a new location. GSAS is looking for the files and I have to
> open the folder in its new location for each image. Is there a way to
> change this?
> Thanks,
> Lisa
> GSAS-II mailing list
> GSAS-II at aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20200513/39ac426b/attachment.html>
More information about the GSAS-II mailing list
