[GSAS-II] GSAS-II Digest, Vol 303, Issue 1
Huang Liu
huang.liu at utah.edu
Sun Apr 25 21:16:19 CDT 2021
Thank you very much for your suggestion. We have Y2O3 in our lab. I will try it. Thank you very much.
Best regards,
Huang
From: GSAS-II <gsas-ii-bounces at aps.anl.gov> on behalf of gsas-ii-request at aps.anl.gov <gsas-ii-request at aps.anl.gov>
Sent: Saturday, April 24, 2021 10:00:01 AM
To: gsas-ii at aps.anl.gov
Subject: GSAS-II Digest, Vol 303, Issue 1
Send GSAS-II mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
gsas-ii-owner at aps.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of GSAS-II digest..."
Today's Topics:
1. Re: Instrument parameters (Leopoldo Suescun)
Message: 1
Date: Sat, 24 Apr 2021 11:53:27 -0300
To: "Toby, Brian H." <toby at anl.gov>
Cc: Huang Liu <huang.liu at utah.edu>, Huang Liu via GSAS-II
<gsas-ii at aps.anl.gov>
Subject: Re: [GSAS-II] Instrument parameters
Message-ID:
<CAAeV=thDqvA0vfZ2a6zoen9tH34vVaG3Y7yPTy8CBnWW2M2_LA at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Hi Brian and Huang,
I use Y2O3 for this purpose. It is not very expensive and got a reasonable
amount of peaks at low angles. In order to minimize size and microstrain
effects, I fire pure Y2O3 for 3 days at 1200 ?C.
I hope it helps.
Leo
El lun, 19 abr 2021 a las 23:59, Toby, Brian H. via GSAS-II (<
gsas-ii at aps.anl.gov>) escribi?:
> Hi Huang,
> First of all Si is not a good standard to use for instrument
> parameters. It has no peaks at low angle. LaB6 is a better choice. If you
> do not have that, perhaps others seeing this can recommend something
> readily available with plenty of sharp peaks.
> GSAS-II has no limits on the number of phases that can be read, but
> there was a bug with reading that particular CIF. In it the element types
> were specified as Ti0, Fe0 and O0 which GSAS-II could not process. I have
> repaired this bug in version #4887.
> Brian
> On Apr 18, 2021, at 6:04 PM, Huang Liu via GSAS-II <gsas-ii at aps.anl.gov>
> wrote:
> Hi,
> This is Huang Liu from the University of Utah. I am trying to use GSAS 2
> to do refinement on my data.
> 1. I try to get the instrument parameters according to the tutorial
> https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/CWInstDemo/FindProfParamCW.htm
> But the U parameters that I get are always negative, and the Rwp is above
> 10. I am using the data generated by*Rigaku mini flex 600 *by *using SRM
> Si 640d* as a standard sample for generating instrument profile
> parameters. The attached file (Si-640d) is the original data.
> Could you please help me generate the instrument profile? Thank you very
> much.
> 2. I try to import Ti2Fe4O phase into the GSAS2, but I failed.
> Since this is the third phase that I want to import. May I ask is there a
> phase quantities limit of import?
> If not, is there anything wrong with my CIF file (I downloaded it from the
> COD website?
> Attached is the Ti2Fe4O cif card downloaded from COD website.
> I would be very grateful if you can help me. Looking forward to your reply.
> Best regards,
> Huang Liu
> <Si-640d.ras><Ti4Fe2O.cif>_______________________________________________
> GSAS-II at aps.anl.gov
#YoUsoTapabocas y mantengo #DFS
Prof. Agr. Dr. Leopoldo Suescun
Cryssmat-Lab/DETEMA, Facultad de Qu?mica, Universidad de la Rep?blica.
e-mail: leopoldo at fq.edu.uy
Tel: (+598) 29290705
Fax: (+598) 29241906*
Mailing address:
Cryssmat-Lab./DETEMA
Facultad de Quimica
Av. Gral. Flores 2124
Montevideo 11800
Uruguay
Seguime en/Follow me at ResearchGate
https://www.researchgate.net/profile/Leopoldo_Suescun
ORC*ID*: https://orcid.org/0000-0002-7606-8074
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210424/0f951807/attachment-0001.html>
Subject: Digest Footer
End of GSAS-II Digest, Vol 303, Issue 1
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210426/33dc6bfe/attachment.html>
More information about the GSAS-II
