[GSAS-II] GSAS-II Digest, Vol 303, Issue 1
Jeremy Karl Cockcroft
jeremykarl at gmail.com
Mon Apr 26 08:16:45 CDT 2021
Dear Huang,
Just to add that, in our labs when working with Cu Ka1 radiation, we have
used Y2O3 for a couple of decades as a standard for instrumental resolution
(and hence peak-shape parameters). Typical PXRD patterns are shown in
the following web pages, e.g.
http://pd.chem.ucl.ac.uk/pdnn/unit1/accurate.htm (XY plot in 2theta)
http://pd.chem.ucl.ac.uk/pdnn/inst2/eddcomp.htm (XY plot in 1/d)
Y2O3 is excellent for generating lots of well-spaced peaks but it is
absolutely *crucial* that it is sintered at high temperature for many days
to improve its crystallinity. Even after sintering at 1200C for 5 days, our
sample still showed slight broadening when Andrew Fitch measured it for me
on the high-resolution PXRD beamline at ESRF (although it showed no
broadening in the lab compared to other standards). However, it is not a
good standard for checking low-angle peaks as the first peak with
significant intensity is at approx. 20 degrees as shown in the patterns.
Cheers,
Jeremy Karl.
p.s. Note that it is not very useful as a standard when working with Mo Ka1
radiation (as used on two of our lab PXRD diffractometers) due to severe
fluorescence.
Dr Jeremy Karl Cockcroft
Department of Chemistry
(University College London)
Christopher Ingold Laboratories
20 Gordon Street
London WC1H 0AJ
+44 (0) 20 7679 1004 (laboratory)
j.k.cockcroft at ucl.ac.uk or jeremykarl at gmail.com
http://img.chem.ucl.ac.uk/www/cockcroft/homepage.htm
On Mon, 26 Apr 2021 at 03:16, Huang Liu via GSAS-II <gsas-ii at aps.anl.gov>
wrote:
> Thank you very much for your suggestion. We have Y2O3 in our lab. I will
> try it. Thank you very much.
> Best regards,
> Huang
> *From:* GSAS-II <gsas-ii-bounces at aps.anl.gov> on behalf of
> gsas-ii-request at aps.anl.gov <gsas-ii-request at aps.anl.gov>
> *Sent:* Saturday, April 24, 2021 10:00:01 AM
> *To:* gsas-ii at aps.anl.gov
> *Subject:* GSAS-II Digest, Vol 303, Issue 1
> Send GSAS-II mailing list submissions to
> To subscribe or unsubscribe via the World Wide Web, visit
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> gsas-ii-owner at aps.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of GSAS-II digest..."
> Today's Topics:
> 1. Re: Instrument parameters (Leopoldo Suescun)
> Message: 1
> Date: Sat, 24 Apr 2021 11:53:27 -0300
> From: Leopoldo Suescun <leopoldo at fq.edu.uy>
> To: "Toby, Brian H." <toby at anl.gov>
> Cc: Huang Liu <huang.liu at utah.edu>, Huang Liu via GSAS-II
> Subject: Re: [GSAS-II] Instrument parameters
> Message-ID:
> <CAAeV=
> thDqvA0vfZ2a6zoen9tH34vVaG3Y7yPTy8CBnWW2M2_LA at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi Brian and Huang,
> I use Y2O3 for this purpose. It is not very expensive and got a reasonable
> amount of peaks at low angles. In order to minimize size and microstrain
> effects, I fire pure Y2O3 for 3 days at 1200 ?C.
> I hope it helps.
> Leo
> El lun, 19 abr 2021 a las 23:59, Toby, Brian H. via GSAS-II (<
> gsas-ii at aps.anl.gov>) escribi?:
> > Hi Huang,
> > First of all Si is not a good standard to use for instrument
> > parameters. It has no peaks at low angle. LaB6 is a better choice. If you
> > do not have that, perhaps others seeing this can recommend something
> > readily available with plenty of sharp peaks.
> > GSAS-II has no limits on the number of phases that can be read, but
> > there was a bug with reading that particular CIF. In it the element
> types
> > were specified as Ti0, Fe0 and O0 which GSAS-II could not process. I have
> > repaired this bug in version #4887.
> > Brian
> > On Apr 18, 2021, at 6:04 PM, Huang Liu via GSAS-II <gsas-ii at aps.anl.gov>
> > wrote:
> > Hi,
> > This is Huang Liu from the University of Utah. I am trying to use GSAS 2
> > to do refinement on my data.
> > 1. I try to get the instrument parameters according to the tutorial
> https://subversion.xray.aps.anl.gov/pyGSAS/Tutorials/CWInstDemo/FindProfParamCW.htm
> > But the U parameters that I get are always negative, and the Rwp is above
> > 10. I am using the data generated by*Rigaku mini flex 600 *by *using SRM
> > Si 640d* as a standard sample for generating instrument profile
> > parameters. The attached file (Si-640d) is the original data.
> > Could you please help me generate the instrument profile? Thank you very
> > much.
> > 2. I try to import Ti2Fe4O phase into the GSAS2, but I failed.
> > Since this is the third phase that I want to import. May I ask is there a
> > phase quantities limit of import?
> > If not, is there anything wrong with my CIF file (I downloaded it from
> the
> > COD website?
> > Attached is the Ti2Fe4O cif card downloaded from COD website.
> > I would be very grateful if you can help me. Looking forward to your
> reply.
> > Best regards,
> > Huang Liu
> > <Si-640d.ras><Ti4Fe2O.cif>_______________________________________________
> > GSAS-II at aps.anl.gov
> #YoUsoTapabocas y mantengo #DFS
> Prof. Agr. Dr. Leopoldo Suescun
> Cryssmat-Lab/DETEMA, Facultad de Qu?mica, Universidad de la Rep?blica.
> e-mail: leopoldo at fq.edu.uy
> Tel: (+598) 29290705
> Fax: (+598) 29241906*
> Mailing address:
> Cryssmat-Lab./DETEMA
> Facultad de Quimica
> Av. Gral. Flores 2124
> Montevideo 11800
> Uruguay
> Seguime en/Follow me at ResearchGate
> https://www.researchgate.net/profile/Leopoldo_Suescun
> ORC*ID*: https://orcid.org/0000-0002-7606-8074
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210424/0f951807/attachment-0001.html
> Subject: Digest Footer
> End of GSAS-II Digest, Vol 303, Issue 1
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210426/e708bad2/attachment.html>
More information about the GSAS-II
