[GSAS-II] Extract number of formula units per unit cell
Ivo Alxneit ivo.alxneit at psi.ch
Mon Apr 26 06:21:16 CDT 2021
Dear all
I am a chemist that uses xrd-powder diffraction to follow the course of
reactions. Therefore, mass-fractions or number of atoms per unit cell
are not useful to me. I deal with mol fractions of formula units (FU).
To convert from the unit cell related values to FU related values I need
to know the number of FUs per unit cell (Z). How can I calculate this
based solely on the information stored in a gsas-II project (I want to
use scriptable to automate the task).
So far I seem to have a solution but I am not sure if it is really correct:
For each phase, the greatest common divisor (GCD) of the site
multiplicity of all atoms corresponds to Z. As example LaFeO3 (Pnma):
La	4
Fe	4
O1	8
O2	4
Formula per unit cell: La4Fe4O12
GCD=4 -> FU=LaFeO3
This also gives the correct FU for solid solutions like Ce0.1Ce0.9O2.
But there are cases where more than one atom form the basis as e.g.
graphite(P63/mmc):
C1	2
C2	2
Formulat per unit cell: C4
GCD=2 -> FU=C2
Here I miss the factor 2 due to the 2-atom basis. How do I identify a
n-atom basis? I assume that in this case I would find for each atom n
sets that have the identical multiplicity. In the case of the LaFeO3
example above a second set with La/4, Fe/4, O1/8, O2/4 would have to be
present.
So the question: Is my solution generic and correct?
Thanks for any help / suggestions
Dr. Ivo Alxneit
Applied Catalysis and Spectroscopy Group
Bioenergy and Catalysis Laboratory        phone: +41 56 310 4092
Paul Scherrer Institute                     fax: +41 56 310 2688
CH-5232 Villigen                      gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/acs/
Desc: OpenPGP digital signature
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210426/a260c204/attachment.sig>
More information about the GSAS-II mailing list
