[GSAS-II] Extract number of formula units per unit cell
Von Dreele, Robert B.
vondreele at anl.gov
Mon Apr 26 07:16:34 CDT 2021
Dear Ivo,
I’m not sure there is a generic solution; following your example Mn3O4 & Fe3O4 each have two different metal atom sites each with different multiplicities in a spinel structure. Since the script is made up of python statements, you could just tailor the math to fit your specific problem & calculate numbers of FUs you want.
Bob
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
From: Ivo Alxneit via GSAS-II<mailto:gsas-ii at aps.anl.gov>
Sent: Monday, April 26, 2021 6:30 AM
To: gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>
Subject: [GSAS-II] Extract number of formula units per unit cell
Dear all
I am a chemist that uses xrd-powder diffraction to follow the course of
reactions. Therefore, mass-fractions or number of atoms per unit cell
are not useful to me. I deal with mol fractions of formula units (FU).
To convert from the unit cell related values to FU related values I need
to know the number of FUs per unit cell (Z). How can I calculate this
based solely on the information stored in a gsas-II project (I want to
use scriptable to automate the task).
So far I seem to have a solution but I am not sure if it is really correct:
For each phase, the greatest common divisor (GCD) of the site
multiplicity of all atoms corresponds to Z. As example LaFeO3 (Pnma):
La 4
Fe 4
O1 8
O2 4
Formula per unit cell: La4Fe4O12
GCD=4 -> FU=LaFeO3
This also gives the correct FU for solid solutions like Ce0.1Ce0.9O2.
But there are cases where more than one atom form the basis as e.g.
graphite(P63/mmc):
C1 2
C2 2
Formulat per unit cell: C4
GCD=2 -> FU=C2
Here I miss the factor 2 due to the 2-atom basis. How do I identify a
n-atom basis? I assume that in this case I would find for each atom n
sets that have the identical multiplicity. In the case of the LaFeO3
example above a second set with La/4, Fe/4, O1/8, O2/4 would have to be
present.
So the question: Is my solution generic and correct?
Thanks for any help / suggestions
Dr. Ivo Alxneit
Applied Catalysis and Spectroscopy Group
Bioenergy and Catalysis Laboratory phone: +41 56 310 4092
Paul Scherrer Institute fax: +41 56 310 2688
CH-5232 Villigen gnupg key: 0x515E30C7
Switzerland
https://www.psi.ch/acs/
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20210426/3ddc1a70/attachment-0001.html>
More information about the GSAS-II
