[GSAS-II] Gsas-ii
kasa belachew kasabelachew at gmail.com
Mon May 23 01:58:14 CDT 2022
Thank you so much!
On Mon, May 23, 2022 at 8:19 AM Magnus H. Sørby <magnus.sorby at gmail.com>
wrote:
> Hi Kasa,
> I don't know what causes the problem, but I'm sure it will be easier for
> the GSAS-II gurus to help if you tell whether this is a problem related to
> a specific GSAS-II refinement, or if it happens in all refinements you run,
> including example gpx files.
> Hope you find a solution! Good luck!
> Magnus
> On Sat, May 21, 2022 at 2:28 PM kasa belachew via GSAS-II <
> gsas-ii at aps.anl.gov> wrote:
>> I using GSAS-II on windows 8 32 bit. Recently GSAS-II keeps crashing
>> every few runs.Always i meet the same error,parameters dropped. error
>> refinement failed.Hessian svd inversion failure.
>> Please help me, how to fix this problem!
>> Below are the screenshots from the console and the refinement box.
>> Thanks!
>> GSAS-II mailing list
>> GSAS-II at aps.anl.gov
>> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
> Magnus H. Sørby, PhD
> senior researcher
> Institute for Energy Technology, Physics Department
> Phone +47 63 80 64 99
> Fax     +47 63 81 09 20
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20220523/43327d22/attachment.html>
More information about the GSAS-II mailing list
