[GSAS-II] GSASIIScriptable command to refine the spherical harmonics ('SH') of the preferred orientation ('Pref.Ori.') parameter
Gunawidjaja, Ray rayg at wsu.edu
Thu Aug 18 14:39:53 CDT 2022
Thanks, Brian, for your reply.
  1.  As you pointed out, another thing I tried was to enable the Pref.Ori. parameter using the following command.
                gpx.phase(0).getHAPvalues('PWDR Si-Beason_2022-R2_csv.csv')['Pref.Ori.']=['MD', 1.0, True, [0, 0, 1], 0, {}, [], 0.1]
Then, I refined using the command:
                gpx.refine()
However, the fit did not seem to converge. On GSASII GUI, the fit converged in less than a minute, so it indicated that something was wrong. Some of the output is as follows:
gpx file saved as C:\Users\ADM\Desktop\57_pXRD_Simulation\pXRD_Simulation_v1-11\data\Tasim.gpx
Hessian Levenberg-Marquardt SVD refinement on 7 variables:
initial chi^2 547.6 with 665 obs.
Cycle 0: 0.06s, Chi**2: nan for 665 obs., Lambda: 0,  Delta: nan, SVD=0
ouch #2 bad SVD inversion; dropping terms for for variable(s) #[0]
giving up with ouch #2
**** Refinement failed with 1 SVD singularities ****
Error: 3 Parameter(s) dropped:
  0:0:MD, :0:Back;0, :0:Back;1
Check covariance matrix for parameter correlation
initial chi^2 nan with 665 obs.
C:/ProgramData/Anaconda3/envs/G2/GSASII\GSASIIstrMath.py:2509: RuntimeWarning: invalid value encountered in sqrt
  A = 1.0/np.sqrt((MD*cosP)**2+sinP**2/MD)
C:/ProgramData/Anaconda3/envs/G2/GSASII\GSASIImath.py:352: UserWarning: Warning: converting a masked element to nan.
  (icycle,time.time()-time0,chisq1,Nobs,lamMax,deltaChi2,Nzeros))
C:/ProgramData/Anaconda3/envs/G2/GSASII\GSASIIstrMath.py:2525: RuntimeWarning: invalid value encountered in sqrt
C:/ProgramData/Anaconda3/envs/G2/GSASII\GSASIIstrMain.py:235: UserWarning: Warning: converting a masked element to nan.
  printFile.write(' wR = %7.2f%%, chi**2 = %12.6g, GOF = %6.2f\n'%(Rvals['Rwp'],Rvals['chisq'],Rvals['GOF']))
C:/ProgramData/Anaconda3/envs/G2/GSASII\GSASIImath.py:230: UserWarning: Warning: converting a masked element to nan.
  G2fil.G2Print('initial chi^2 %.5g with %d obs.'%(chisq00,Nobs))
  1.  The above command is for MD model. I copied from the example provided on the website https://gsas-ii.readthedocs.io/. For SH model, what is the equivalent command to do a spherical harmonic model with order 2? When I tied the following, it did NOT work:
                               gpx.phase(0).getHAPvalues('PWDR Si-Beason_2022-R2_csv.csv')['Pref.Ori.']=['SH', 'order':2, 'refine': True]
Ray
Sent: Thursday, August 18, 2022 2:23 PM
To: Gunawidjaja, Ray <rayg at wsu.edu>
Cc: gsas-ii at aps.anl.gov
Subject: Re: [GSAS-II] GSASIIScriptable command to refine the spherical harmonics ('SH') of the preferred orientation ('Pref.Ori.') parameter
[EXTERNAL EMAIL]
Hi Ray,
  As of right now, it does not appear that I have written an API to set the model type and parameters for preferred orientation. GSASIIscriptable only is able to turn on and off the refinement flag. This does not mean it can’t be done, but it needs some special attention. You can use phase.getHAPvalues() (https://gsas-ii.readthedocs.io/en/latest/GSASIIscriptable.html#GSASIIscriptable.G2Phase.getHAPvalues) on an .gpx file edited with the GUI to see the dict with all the parameter values so you can see what you want to change and then use .setHAPentryValue (or modify the dict directly) to make the changes.
   What you want is something that probably should be implemented, but my recollection is that it is not a simple task, as the Laue group for a phase determines now many terms are allowed for a given SH order and that means to implement a generalized scripting routine that allows one to set the SH order requires creating access to a bunch of routines currently only implemented in the GUI. I know I am not going to get to that anytime soon, but f important to your work keep asking iand I’ll add it to my to do list.
Brian
On Aug 18, 2022, at 1:13 PM, Gunawidjaja, Ray via GSAS-II <gsas-ii at aps.anl.gov<mailto:gsas-ii at aps.anl.gov>> wrote:
Hello,
I am trying to include preferred orientation refinement into the example script below (in red font), but can’t find the right command on the website (https://gsas-ii.readthedocs.io/en/latest/). I would like to achieve the same result as selecting the Spherical harmonics Preferred orientation model with, e.g., a harmonic order of 2 in the Data table in GSASII GUI. to Please help.
    from __future__ import division, print_function
    import os,sys
    sys.path.insert(0,'/Users/toby/software/G2/GSASII') # needed to "find" GSAS-II modules
    import GSASIIscriptable as G2sc
    datadir = "/Users/Scratch/"
    gpx = G2sc.G2Project(os.path.join(datadir,'test2.gpx'))
    gpx.histogram(0).add_back_peak(4.5,30000,5000,0)
    pardict = {'set': {'Sample Parameters': ['Absorption', 'Contrast', 'DisplaceX'],
                       'Background': {'type': 'chebyschev-1', 'refine': True,
                                      'peaks':[[0,True]]},
                         'Pref.Ori. ':{ 'type': 'SH', ???????}
           gpx.set_refinement(pardict)
I appreciate your help.
Ray
GSAS-II mailing list
GSAS-II at aps.anl.gov<mailto:GSAS-II at aps.anl.gov>
https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20220818/07bda2bb/attachment-0001.html>
More information about the GSAS-II mailing list
