[GSAS-II] Bug when copying Sample parameters
Lukas Grossmann Lukas.Grossmann at frm2.tum.de
Fri Aug 26 09:35:29 CDT 2022
Dear all,
i think i found a bug in GSASII. I try to make a sequential refinement
on up to 300 datasets. And I want all the datasets to have the same
sample parameters. So i set the right sample parameters for the first
dataset (which is with Debye-Scherrer as diffractometer type). Then i
press copy->set all->Ok. So it turns out that everything is copied to
the other datasets but not the Diffractometer type which still reads
Bragg-Brentano (which is the default one). I dont really want to go
through 300+ datasets all the time to set it to the right type. Does
anyone else experience this error? I am currently working on a linux
machine, maybe thats the problem. I am thankful for any help or work-around.
Best regards,
Lukas Grossmann
Dr. Lukas Grossmann
Forschungsneutronenquelle Heinz Maier-Leibnitz (FRM II)
Technische Universität München
Arbeitsgruppe Advanced Materials
Lichtenbergstr. 1
85748 Garching
Raum UYW05 42
Tel: +49 (0)89 289 54725
Mob: +49 (0)178 197 5707
More information about the GSAS-II mailing list
