[GSAS-II] Bug when copying Sample parameters
Lukas Grossmann
Lukas.Grossmann at frm2.tum.de
Mon Aug 29 02:16:32 CDT 2022
Hi Brain,
so i could solve my problem with "copy selected" which worked. Of course
it would be great if you could help me making a instrument parameter
file. What information do you need. This is what i use at the moment:
#GSAS-II instrument parameter file; do not add/delete items!
Type:PXC
Bank:1.0
Lam1:0.709319
Lam2:0.713669
Zero:0.005813437651804393
Polariz.:1.0
Azimuth:0.0
I(L2)/I(L1):0.4677557702535342
U:16.943024265266104
V:-1.354593847339369
W:0.734847151049728
X:0.940919681175115
Y:3.519782091472069
Z:0.0
SH/L:0.03295419890626254
Source:Mo
Best regards,
Lukas
On 27.08.22 14:32, Toby, Brian H. wrote:
> Changing the instrument type is not something one should do most of
> the time and we certainly don’t want it to be something one does by
> accident. Do you need help making an instrument parameter file to
> match your data source?
> Brian
> Sent from a powerful small device but with weak eyes.
>> On Aug 26, 2022, at 10:35 AM, Lukas Grossmann via GSAS-II
>> <gsas-ii at aps.anl.gov> wrote:
>> Dear all,
>> i think i found a bug in GSASII. I try to make a sequential
>> refinement on up to 300 datasets. And I want all the datasets to have
>> the same sample parameters. So i set the right sample parameters for
>> the first dataset (which is with Debye-Scherrer as diffractometer
>> type). Then i press copy->set all->Ok. So it turns out that
>> everything is copied to the other datasets but not the Diffractometer
>> type which still reads Bragg-Brentano (which is the default one). I
>> dont really want to go through 300+ datasets all the time to set it
>> to the right type. Does anyone else experience this error? I am
>> currently working on a linux machine, maybe thats the problem. I am
>> thankful for any help or work-around.
>> Best regards,
>> Lukas Grossmann
>> Dr. Lukas Grossmann
>> Forschungsneutronenquelle Heinz Maier-Leibnitz (FRM II)
>> Technische Universität München
>> Arbeitsgruppe Advanced Materials
>> Lichtenbergstr. 1
>> 85748 Garching
>> Raum UYW05 42
>> Tel: +49 (0)89 289 54725
>> Mob: +49 (0)178 197 5707
>> GSAS-II mailing list
>> GSAS-II at aps.anl.gov
>> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
Dr. Lukas Grossmann
Lichtenbergstr. 1
85748 Garching
Raum UYW05 42
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20220829/80d50271/attachment.html>
More information about the GSAS-II
