[GSAS-II] Inquiry reg setting up the instrument param file
Thanos Goulas A.Goulas at lboro.ac.uk
Wed Dec 18 17:49:18 CST 2024
Dear GSAS-II community,
I have been working on setting up the instrument parameter file for a Bruker D2 in GSAS-II, using SRM 660 and 640 standards. However, I am encountering issues with peak identification, particularly with peak splitting at higher 2θ angles.
Given this, I was wondering if stripping the ka2 component is an absolutely necessary step for this process?
When I limit my 2θ range to 20–80°, I manage to obtain reasonable U, V, W, X, and Y parameters. However, these parameters go spammy when I attempt to refine them over a broader range, such as 5–140° (to get the D2's full profile)
Finally, shouldn't I be getting the same parameters regardless of the standard I am using? LaB6 and Si produce completely different params.
I would greatly appreciate your thoughts or suggestions on this.
Looking forward to your insights.
Thanos
Dr Thanos Goulas, BEng MSc PhD
Pronouns:<https://urldefense.us/v3/__https://www.mypronouns.org/__;!!G_uCfscf7eWS!Yq11gnqmg3M9-lh3tSzSV6QYuF1RAU_nfVcoSVmiiLRLWZUSOovRxbxHMf22yQ8Xcgau-y3QZLQuqTD66ep4j6E$ > he / him / his
School of Aeronautical, Automotive, Chemical and Materials Engineering
Department of Materials
Loughborough University, Loughborough, Leicestershire, LE11 3TU, UK
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20241218/b7710cd6/attachment.html>
More information about the GSAS-II mailing list
