[GSAS-II] Unable to index magnetic reflections
אלעד כספי eladc at iaec.gov.il
Sat Mar 28 13:19:38 CDT 2026
Hello,
I am a new user to GSAS-II (and a very "old" user of GSAS/EXPGUI).
I plan to use it mostly for magnetic structure refinement.
I have 2 issues:
1. The request for magnetic symmetry from Bilbao Crystallographic center
doesn't work. I understand that this issue is in the process of being
solved.
2. When I add a magnetic phase "by hand" the indexing part doesn't work.I
go to the "Unit Cells List", check the "magnetic?" box and play with the
"red"/"black" options of the desired magnetic phase diagram. I do that for
the LaMnO3 simple magnetic structure analysis example given in GSAS-II
site. However, nothing changes. No additional indexing appears in the plot
window. When I change the crystallographic (not magnetic) space group, the
indexing do change accordingly.
I am using version 5833/v5.7.4
Thank you,
El'ad
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20260328/aeed8bf5/attachment.html>
More information about the GSAS-II mailing list
