[GSAS-II] Unable to index magnetic reflections
Toby, Brian H. toby at anl.gov
Sat Mar 28 13:50:14 CDT 2026
This is still not working. See https://urldefense.us/v3/__https://github.com/AdvancedPhotonSource/GSAS-II/discussions/294__;!!G_uCfscf7eWS!cXVt_DdgtRkkHMYb42g-II5tsYKJHf1Ks9E3Q7FP0OwOBmPZ2Jey-kkaGOb0QIfDYAWGx6qNadedYpo$ <https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2FAdvancedPhotonSource*2FGSAS-II*2Fdiscussions*2F294&data=05*7C02*7Cgsas-ii*40aps.anl.gov*7Ce35b49903f744e8fe09b08de8cfad8f1*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639103206190576010*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=bPZPEsRoX0aQ2g*2F*2BBoSMQvhIM9lb1uweSBMlYBY9ACc*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJSU!!G_uCfscf7eWS!cXVt_DdgtRkkHMYb42g-II5tsYKJHf1Ks9E3Q7FP0OwOBmPZ2Jey-kkaGOb0QIfDYAWGx6qNetT0FZk$ > and https://urldefense.us/v3/__https://github.com/AdvancedPhotonSource/GSAS-II/issues/313__;!!G_uCfscf7eWS!cXVt_DdgtRkkHMYb42g-II5tsYKJHf1Ks9E3Q7FP0OwOBmPZ2Jey-kkaGOb0QIfDYAWGx6qNs2fpSq8$ <https://urldefense.us/v3/__https://gcc02.safelinks.protection.outlook.com/?url=https*3A*2F*2Fgithub.com*2FAdvancedPhotonSource*2FGSAS-II*2Fissues*2F313&data=05*7C02*7Cgsas-ii*40aps.anl.gov*7Ce35b49903f744e8fe09b08de8cfad8f1*7C0cfca18525f749e38ae7704d5326e285*7C0*7C0*7C639103206190604901*7CUnknown*7CTWFpbGZsb3d8eyJFbXB0eU1hcGkiOnRydWUsIlYiOiIwLjAuMDAwMCIsIlAiOiJXaW4zMiIsIkFOIjoiTWFpbCIsIldUIjoyfQ*3D*3D*7C0*7C*7C*7C&sdata=zBya*2F6GNqTvJyFhNKzsPt0WYEZIX8naz0EIlHDD7HU0*3D&reserved=0__;JSUlJSUlJSUlJSUlJSUlJSUlJSUlJSUlJQ!!G_uCfscf7eWS!cXVt_DdgtRkkHMYb42g-II5tsYKJHf1Ks9E3Q7FP0OwOBmPZ2Jey-kkaGOb0QIfDYAWGx6qNz-bYYt4$ > for why and some workarounds. The good news is that this is being worked on, with software being updated both in GSAS-II and Bilbao, so there is some hope that this will be fixed pretty soon.
Brian
From: GSAS-II <gsas-ii-bounces at aps.anl.gov> on behalf of אלעד כספי via GSAS-II <gsas-ii at aps.anl.gov>
Date: Saturday, March 28, 2026 at 1:20 PM
To: gsas-ii at aps.anl.gov <gsas-ii at aps.anl.gov>
Subject: [GSAS-II] Unable to index magnetic reflections
This Message Is From an External Sender
This message came from outside your organization.
Hello,
I am a new user to GSAS-II (and a very "old" user of GSAS/EXPGUI).
I plan to use it mostly for magnetic structure refinement.
I have 2 issues:
1. The request for magnetic symmetry from Bilbao Crystallographic center doesn't work. I understand that this issue is in the process of being solved.
2. When I add a magnetic phase "by hand" the indexing part doesn't work.I go to the "Unit Cells List", check the "magnetic?" box and play with the "red"/"black" options of the desired magnetic phase diagram. I do that for the LaMnO3 simple magnetic structure analysis example given in GSAS-II site. However, nothing changes. No additional indexing appears in the plot window. When I change the crystallographic (not magnetic) space group, the indexing do change accordingly.
I am using version 5833/v5.7.4
Thank you,
El'ad
URL: <http://mailman.aps.anl.gov/pipermail/gsas-ii/attachments/20260328/97cb63e3/attachment-0001.html>
More information about the GSAS-II mailing list
