[GSAS-II] How to generate the ".raw" file from scratch
Toby, Brian H.
toby at anl.gov
Sun Jan 13 13:05:53 CST 2019
First of all, there are several different file formats that use the .raw suffix, so you should specify which one you want. Knowing what you want to do with this .raw file might make this question more clear (and there may be easier choices). In any case, unless someone (not me) wants to write an exporter for the particular .raw version that you want, GSAS-II is not going to write that.
If you are running on Windows, you might look into PowDLL. I am not sure if it can write what you want, but it does handle a lot of different formats. There are several other format converters, but I know little on this subject.
Brian
> On Jan 13, 2019, at 3:27 AM, Qiyuan Lin via GSAS-II <gsas-ii at aps.anl.gov> wrote:
> Dear everyone,
> I am attempting to generate the ".raw" file from a counts vs. (deg)2theta two-column file. Has anyone done this before? Or is it even possible to do so? Any suggestions or hints would be highly appreciated. Thanks.
> Best regards,
> Qiyuan
> Qiyuan Lin
> Ph.D. Candidate, Zangari Group
> Materials Science and Engineering
> University of Virginia
> GSAS-II mailing list
> GSAS-II at aps.anl.gov
> https://mailman.aps.anl.gov/mailman/listinfo/gsas-ii
More information about the GSAS-II
